Help with installing illuminating door sills!
kolourhero
you could probebly get by just twisting the wires and using electrical tape, but i chose to solder. it takes longer to expose the wires and tape up than it does to solder.
simo i guess you could dry the sealant the clear sealant that they use in bathrooms.. or something equally as strong?
if you use some sort of glue, make sure you remove the doublesided tape... btw, did you clean your stock doorsills before sticking these things on?
i know my back drivers side doorsill is rubbing when the door opens/closes, but it doesnt fall off coz its not sticking to the stock doorsill.
    2. 4
      RATTLING CAMRY 2013
      Canning Prado or 200
      2002 Door Handle Issue
      What to say!
    10. 1
      Just joined
