my gears crunch when going into 2nd
black turkey
hey guys, this has been happening for a while and only after not having my car for a while and forgetting about it have i remembered to ask about it (make sense?). anyway, ever since i replaced my cars clutch, it has been hard to get into 2nd from 3rd and it crunches. it ONLY happemed when downshifting into 2nd and ONLY happened when the car is cold and i shift into the gear casually (i.e driving to school in the morning i drive slowly through my neighborhood), it wont crunch if its warm or if its cold and i quickly and spiritally chenge gears to 2nd.
so any help will be wicked. my dad reckons he doesnt notice it and there is no problem. but it definately wasnt there before i got the new clutch
may your pedal needs to be adjusted
that happened to mine
the pin on the pedal where you adjust came loose and just kept going lower so my clutch was activating as much
so check that your brake pedal and clutch pedal are in line with eachother
mine did the same
it got really hard to change
now its fine
but sometimes if i try to change from first to second when i floored it and it gets to about 6000 revs it crunches into gear
annoying if i try go
haha
but oh well
ok sweet ill give it a shot. also its not worth making another thread but do anyone of you guys get (i think its called) axle tramping? its when you try or accidently do a burnout it feels like **** and the car shakes like the tyre gets grip and looses it all the time? it even happened when the place i works carpark is soaking wet.
so if i go ahead and chuck king lows (or super lows?) will that be like replacing my suspension or is it a different part? i thought it was cos my car hadnt got enough power to pull a burnout but my sisters festiva could do it lol. so would lowering my car with king springs solve both issues (burnout thing and lowering the car)?
It also could be your syncros...
Mine are going on third (sometimes it grinds going into third) aparantly 2nd and 3rd syncros are a common problem with ST184/ST185 celicas
That sounds like axel tramp to me;
What size rims and tyres are on the celica, and how good is your clutch?
Edited by mick.wheelz
they're shorter
cause
think about it
a normal car
normal shocks
shocks have like a chamber inside
with a piston
so if you lower the car
you take away room for the piston to move
so if you hit a pot hole
BANG
the piston hits the bottom
lowered pistons are shortened with a longer chamber
but king springs should have them
or head over to pedders or something hey
either one
oh ok i see, sorry im a newby in this area. so if i go to a place that sells and fits a full kit that lowers my car (for example whatever you buy when you get a kings super low kit) ill get everything i need (which i would expect) and this most probably fix my axle tramping ****. sounds good but i remembered one problem.
when i go over bumps (not speed bumps, but sudden rises in the road) or if i hit over a dip at a high speed, the outside of my tyre hits against the egdge of the fender where the wheel goes (?). what i mean is that the tyres i have which are 205.50.16 stick out of the wheel arch by about half a centimetre and when the car hits a bump big enough, the trye hits against the edge of the wheel arch. the suspension doesnt bottom out that i know of, cos inside the wheel arch there is lots more room for the tyre to rise.
so if i lower my car this problem will get worse wouldnt it?
since you said the problem started after clutch changed and when its cold,the problem is more likely because of thicker oil has been used.
on ST184 using Dextron 3 is more than enough,if doesn't help than it is time to change synchro...but if you happy enough to wait until it warm up then don't worry unless it getting really bad.
with axle trampling also possible that the engine mount getting sloppy,put urethane or silicon...may increase the engine vibration though or you may like to replace it.
or course it possible that the shocker gone since ST184 strut a bit ****ty,but usually the car will be all over the place and feel woolly like French car
the mounts bolt to both the car and the engine
so if you change then engine to a different engine
you will be changing all the mounts and moving
which might be modifying the crossmember
yeah its the same type of motor just its been replaced. si its a different motor but the same engine. so its a 50% chance if they use the old mounts to the new ones isnt it?
okay then. im gonna go around to places tommorrow to see how i will go about getting new springs and maybe lowering (depending on whats happening with the tyre problem) it. but i have to buy new back tyres now at the moment cos some **** head stabbed my cars tyres and the car next to mines with a drill or something while at school.
well i wanted to end up with eagle F1's all round but they are only on the front and i was gonna just move the fron tones to the back when the time comes and get more. but im poor and food is more important that rubber... unless i can go to my parents house for food hmmm
Syncro cost stuff all, even at toyta's inflated spare parts prices $100 would more that cover it. It is huge job to change them though. Sometimes not possible to do correctly when DIY as you need special tools.
hey does anyone know how much syncros would cost for for our cars??
      2000 Corolla Ascent - clock.
      ST205 for sale
      Rukus for sale
    5. 8
      CH-R sudden engine failure
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
    9. 12
