radio install
takerboy
hi guys i was installing a new cd player into my 02 corolla and everything was going good until i noticed that there was an extra wire i have since been told that its an illumination wire what do i do with it? i had my cd player working till night time when i turned on my lights and it busted a fuse for my dash lights that dosnt seem good. i have put cd players in cars b4 and never had issues like this if anyone could help that would be great, i know i could just spend 80 bucks and get it done but i would like to know whats going wrong
ta
The extra wire, did you tape it up before you put the head unit in? If not it may be touching something metal and causing your fuses to blow. Does the 2002 Corolla have a power antenna? If it does that could be what the extra wire is for, modern cars don’t seem to have extra illumination wires (that I’ve seen), they just always illuminate (great how modern LEDs outlast the cars). If it’s for the antenna its perfect for powering your amp if you have one.
Check the extra wire is sealed and try again.
    2. 83
    3. 26
    4. 2
    5. 2
      Head Unit with Apple CarPlay
    6. 3
      Invisible Instruments fix
      Can I use USB hub to get more USP ports?
    10. 1
