Hi i have 2005 camry sportivo, can this car install H.I.D Conversion kit ? and make i ask how much $ is worth ?
yep u can..check wat type of globe uve got in there originally & then check ebay or stockist of a good quality HID units as they can vary from couple hundred to over a grand..depending on brand as well
Posted (edited)
It alls depend on how much you are willing to spend $$$$$ and also the quality of the HID whether it is used or brand new.
Last time i get an used HID for 100 bucks and it was a 7000k and the HID last for a long time it was from japan....last time i was also doing a lot of research to buy an HID for my 2003 camry sportivo and it ends up with these choices......
HID From China = $ - easy to die
HID From Taiwan = $$ - same quality with china but better
HID From Japan = $$$ - very good quality but expensive
HID From German = $$$$ - excellent qualitybut the most expensive
Some websites you may get the information about the HID: www.firesport.com, ebay.com, quicksales.com.
HAPPY CHOOSING :)
Edited by EMBUN
phillips hid kit :) about $450-550. bang for buck! pay for what you get.
jus wondering if anyone has a step by step instruction or some sort for me to DIY HID Kits onto my ACV40R Camry Sportivo
^ i think the diy is like with every car, maybe look up for a corolla diy, their seem to be a few around there.
haha .. I just want to play safe ! its my first time DIY.. I dont want to read something different andhalf way I see my engine dropping out from its bay.
when u actually look at the vid on youtube and the instructions in this forum, u will know your engine wont drop from its bay.. start searching and reading/watching.
if you know how to remove your bulbs, im sure your pretty safe.
This is what I recommend, a relay-harness to ensure your stock wires don't go astray:
Here's a photo of the wiring diagram i used when I was doing the 1st retrofit
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
