problem with my tires need help asap pls!!!
aqi38l
hey guys & girls,
i recently brought some 17 inch wheels for my corolla sportivo, and the tyres that got put on is 215/45-17 and the front driver side is hitting the thin piece of plastic and its made a hole in it. Plus every time i turn left is making noises. Right now its running 40psi and i was wondering if i can drop the front to 36psi and the rear 38psi?? And i would like to know if it will cause damage to the body if i dont drop the tyre pressure.
Cheers Lucas
hey guys & girls,
Cheers Lucas
wat offset wheels do u have and how low is ur car?
i never had a problem when i was running that profile.
    2. 16
      2000 Corolla Ascent - clock.
      ST205 for sale
      Rukus for sale
    6. 8
      CH-R sudden engine failure
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
