Hi all Tarago owners
I would like to change spark plugs on my Tarago 1994.Could someone help me ?
The engine is found under the seat next to the driver.Could it be under my seat ?
I am getting a light ignition problem and bought titanium heads spark plugs as they yield heaps of Kms.
I have noticed that on short trips driving in town,its a drunkard.Over long distances it performs quite economical for an 8 seater.
You have to remove the drivers seat, fold back the carpet and you'll expose an engine cover...
Undo all the bolts and lift the cover off and you'll see the top of the engine...
Take off the black cover, high tension leads and pull the plugs out :) :) :) ...
Thanks for your tips Rolla !! :
  • 8 months later...
  • 4 weeks later...
Remove (Black) cover over the rocker cover to expose the leads.. You WILL need an extension bar with your spark plug socket as they are fairly deep into the rocker cover...
Hope this helps.
Cheers
  • 2 months later...
thanks for the tips also
    2. 1
      Tyre Sale Specials
    3. 0
      overheated engine
    4. 1
    5. 62
    6. 1
    7. 1
    8. 1
      Tyre Sale Specials
    9. 10
      Android auto
    10. 0
