Hey guys
I've acquired an auto Corona S (ST141) from my Dad... engine is f*#ked (read: oil and water ****** out the side of the block)
What, if any, other toyota engines can replace it and how easy are they to come across
Cheers
Dee
  • 4 weeks later...
Hey guys
Cheers
Dee
Go to Wayne Stephensons site and see the variations.
ST141 will take a 3TGTE if its rwd and thats areal hoot
Was calleda corona GTT
Look up on Google Corona GTT
22RE from an RT142 Corona is an easy replacement, as you can switch everything over from the 142.....does require EFI conversion though obviously. If you want to splurge a bit more, go a 1GGTE from a Soarer or Supra, fairly easy to find and has been done a thousand times before. 3TGTEs are getting rare and old, with parts (like distributor cap) that cost a motza to replace. Personally I'd avoid them.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
