Head light bulb
ooy33h
Guys,
Before i get flamed, i did try the search button.
1. Can someone please confirm the head light bulb on the 05 corolla sportivo?
2. is the high and low beam one bulb?
3. what is the bulb for the spotties?
4. what socket to suit the parkers?
thanks guys
steve
05 rolla should be using H7 :)
high beam and low beam are separate...
whats spotties? :P
parkers r T10
anyone pls correct me if im wrong :)
Thanks Jeremy,
Also can someone confirm this as i have been told its using HB4 Socket
I meant spot lights or fog lights...
Have just confirmed..
High Beams - HB3
Low Beams - H7
Fog Lights - H11
its in the manual :)
No, high beams are H7 on a hatchback. Flip forward a few pages in the manual Jeremy. You were looking at the sedan/wagons bit.
High Beams - HB3
Low Beams - H7
Fog Lights - H11
Are you sure high beams is H7 in hatch? My lowbeams is H7. btw I have facelift. Probably makes a diff.
High Beams - HB3
Low Beams - H7
Fog Lights - H11
yeah forgot to say..does facelift n prefacelift have diff bulbs??
Yeah, what Brad said was correct.
In a facelift corolla (hatch),
H7 for both high and low beams.
h11 for fog lights.
and t10 for parkers.
Oh yeah, and I'm definitely sure, as in my facelift corolla I've moved my previous low beams bulb to the high beams. In the hatch they're just H7 globes inserted from the side. See page 261 of the facelift corolla manual. =)
Regards,
Kenneth
Edited by KT668
