my name is keith i,m from W.A
never had a tarago before..1994 gli..nice vans
how do you get to the spark plugs and oil change....it has a oil tank under the bonnet..do i fill it there or under the passenger seat
thanks....
how much oil???
any performance tips
Drain the oil and change the filter...
Then fill it up from under the passenger seat (should be 5.5 - 6.5 Litres I THINK - Don't quote me on this)...
Put in 5 litres, start it up for 2 mins, turn it off and check the level... Top it up as necessary...
Once you've reached the full line on the dipstick, then top up the oil resorvoir under the bonnet till you reach the full line...
This seperate tank is used as an oil reserve if needed...
Also, with your spark plugs, you'll have to remove the drivers seat, the carpet and the engine covers to get to the spark plugs...
Posted (edited)
thanks again
found out its a 2TZ motor twin cam
any idea of the wheel offset ???
was told it was 50+ 5x114.3 after a set of mags for it
found a set from celica....................
Edited by vintageholden
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
