Kings or Pedders??
ELEGNT
There is only 2 options at the moment for springs in the Aurions and that is king lows or pedders. the trend with the other owners is to go with the pedders.
Wait 6 months or whatever until Lovells or Whiteline bring out a spring and buy those instead?
lovells have got a spring but noone knows hoe good they are
If the Lovells spring is just as good as the ones they've done in the past, then it'll be better than Kings.
from experience of 18" rim on camry with Kings, and 20" rim on aurion with pedders.. as they are different size so it isnt that accurate to compare in this way..
but from wat i feel, they are very much the same or at least very similar.
but on camry, it was low for front and super low for rear, it then looks more like same drop/height..
on the aurion, there isnt low or super low to choose from IMO, but the drop was not tat bad, as seen on the pic posted in aurion section.
price? not much difference too(very little).
I think tyres play a MAJOR part in comfy and ride too, this is wat i found when i was using a sh!t/out of shape tyre, then Nankang then "another brand" i forgot.. Dont just spend so wisely only on suspension and totally missed out the tyre part..
the tyre load(if u wan your tyre to wear 200% faster and goes out of shape), other stuff are important too..
      help with clutch
    5. 3
      newbie from Queensland
      High mileage camry
      1981 Hiace ignition upgrade
    8. 2
    9. 1
