aftermarket spark plug led
hey guys. has anyone tried aftermarket spark plug led (Corolla zze122 or zze 123)? is that good? because i found the website that mention after you change the spark plug led, the hp can increase 5-10%. is that correct? any brands suggest? if so, please leave model, parts numbers and the place can buy.
http://www.nology.com/hot.html
cheers
Dennis
cheers
Dennis
TRD.
http://www.trdsales.com/shop/product.asp?catcode=213
i checked the trd website and they don't have the spark plug led for zze122 (1zzfe engine). if you konw the parts numbers, can you post it or post the other brand that you know.
cheers thanks :rolleyes:
Have you guys ever opened your bonnets and had a look for the stock spark plug leads?
You have the toyota coil on plug setup, so you dont have spark plug leads to replace.
cheers
Dennis
TRD.
cheers
Dennis
TRD.
if i want to upgrade ignition system on zze122, what should i do? any comment?
Dennis
cheers
Dennis
If you really wanna upgrade the spark plug lead, try to look into the NGK Power Cable.
Also, there is a device from HKS "HKS Twin Power". However, I have no idea what's that call in English. I read it from an foreign mag. The device is just a little box, what it does is to increase the length of the time that the spark plug ignite.
I read about this on a mag, a guy who has a Toyota Aristo(Jap Spec) have mod the car seriously has the HKS Twin Power under the hood.
If you are interest, maybe you can search on the internet for "HKS Twin Power"
Hope that helps...... :lol:
Edited by Cooley
      Aftermarket Air Intake
      Heater problems
      Entertainment Unit Upgrade
      Seat change
      1993 Corolla Seca CSI limited
      Corolla Seca For Sale
      High mileage camry
