ecu, unichip or emanage?
trd
grabbing a second hand emanage is better value for money than the unichip, and you can do a lot more with the emanage yourself than you can with the unichip(which is basically nothing).
Both are piggybacks, the emanage had more features the last time I compared them.
http://www.mohdparts.com/emanage/EmanageFAQ.txt
how much is it and where can i buy it in aus?how to tune?
cheers mate
trd
I've bought a couple of complete setups from forums for $500 now including the support tool cable, injector and ignition looms.
You tune it with a notebook pc on a dyno or on the street with a wideband setup.
The install I did on MAP81's 1ZZFE is here: http://au.toyotaownersclub.com/forums/inde...wtopic=1024&hl=
Edited by rollamods
      Drive shafts
    3. 10
      front brake calipers
      Drive shafts
    7. 315
    8. 10
      Dashlight dimmer
