zze123 trd rear strut brace vs ultra racing rear lower bar
31
Adding cruise control to a 2008 Ascent Hatch
I know there is a heap of discussion out there on this topic but has anyone successfully added cruise when the wiring harness doesn't support it? I was a hoping to just buy the clock spring and cruise stalk and fit it, but mines a manual and there is no wiring to connect the clutch switch to. I've read about people running wiring to the ECU, but there weren't any clear guides for this that i could find. How do you actually tap into the ECU connector because the pictures I've seen look like it wouldn't be easy to add anything to it? I gave up after seeing there was no clutch switch cabling to wire up to so I don't even know if the necessary cabling is between the clock spring and the ECU. Has anyone done this mod on a car that isn't pre-wired for it? -
Handbrake gap in coonsole
Just purchased a 2008 Corolla hatch. As shown in the photo, the rubber shroud attached to the handbrake sags down and leaves a big gap for things to potentially fall down in there. I can't figure out why its like that. Nothing seems to be broken - is there something missing from there? -
high fuel usage
Hi guys i have an 2009 with a 4l petrol and has suddenly started using more fuel. was wondering if any one else had this problem at all. no fault codes, new spark plugs thinking it may be o2 sensors or blocked cat, any help diagnising would be great cheers -
Rukus for sale
Hi, I have a one owner top spec Rukus about to be placed for sale in Melbourne. It's a deceased estate and likely one of the cleaner and low mileage examples available for sale. Thanks. -
Wanting to buy ruckus
Hi I don't suppose you're still after Rukus, I have a very clean one owner top spec example about to be up for sale. -
Typical Price for a Replacement Key - 2000 Toyota Torago
That's expensive for a steel key. Https://www.keysocallaghan.com.au -
