Tyres for 15" &/or 16"
Conquest
Ok rego's coming up and I need some new tyres. Still undecided whether to keep my 16" 205/50/16 or go back to stock 15" 195/60/15 as I probably won't be in the country much longer so i'll be giving the car to a relative while i'm gone.
One of the few 'legal' 16" options seems to be Toyo Proxes and they get pretty good reviews, are they still around $180 a piece?
Apart from that it looks like Bob Jane has a special on 15" Yokohama A Drives @ $142 a piece, is this good value?
Will probably check out the local Tyrepower and Blairs in the coming weeks, any other suggestions are more than welcome...
Which A.Drives are you referring to? Because Yokohama make two different A.Drives; the R1 is the performance one.
15inch......can buy good performance tyres at a cheap price.......
195 * 55 * 15 - Bridgstone Adrealines. GIII's. @ $120 Per tire from Kmart Tire and Auto.
Excellent Road tire.
I used them for a track day. Excellent grip levels.
This one
No mention of R1 or performance so I assume they're standard tyres.
How is the Bridgestone all round performance, wet weather and noise? As I said i'll most likely be giving the car away so first and foremost i'm after something safe and comfortable.
      ‘97 Petrol 6 cyl ‘80 Series knocking/rattle below
      1989 Hilux Low Voltage
      Ae92 genuine low ks 70800
      Code P004B
    9. 1
