Replacement springs for 2016 Aurion Sportivo
Hi, I am trying to find standard or raised height firmer than stock springs for a 2016 Sportivo. Does any one have a set for sale or know of anyone who still makes them or may have stock. Don't want to go to Coilovers , but need to raise the ride height slightly to save the front spoiler and stop scraping the tow bar all the time in parking lots and steep driveways. I need to replace the shocks now, and would prefer to do the springs at the same time, but there does not seem to be anything available Any help appreciated -
RAV4 19" wheels on Aurion
Layed down 4 coats of satin black, & 3 coats satin clear. Am quite happy with the finish, and a noticeable difference in comparison to the original black gloss. Can't wait to get 'em on the car 👍 -
1992 1hdt both blinkers flashing together
OK, pulled out the blinker control stalk and cleaned it with contact spray, problem still there. Disconnected the hazard warning switch and no blinkers at all. Not sure if the blinker relay gets its power through the hazard switch, if so this could be normal. It’s looking like a trip to the auto electrician as without a cct diagram I’m just chasing my *****. -
Alot of plant debri flying around today. Whipped up a spray booth. Not ideal, but it's what I've got to work with. Let the painting begin 👍 -
New Headlights Flickering Out
I installed new headlight bulbs in my 2007 RAV4 recently. However, every time I turn them on they both flicker out simultaneously after about 5 seconds. What could cause this issue? I don't think it is the bulbs because they can be turned back on again, and there are no blown fuses. A friend mentioned something about a ballast, but I am not knowledgeable enough about car electrics to do anything about that. This is the description of the bulbs: Product: HID Xenon Bulb Material: Quartz tube + iron bracket Voltage: 12V Bulb Type: D4S (can also fit D4C, D4R as well) Base Type: P32d-5 Power: 35W/Bulb Light Source: Xenon HID Light Color: Yellowish White light Color Temperature: 4300K Luminous flux: 4500LM ± 200LM Waterproof: IP65 Beam Type: Hi/Low Beam Part Number: 66440CLC Bulb Size: ( L x W ): 7.5 x 3.2cm Socket Base Dia. : 1.8cm Weight: 200g approx, I would appreciate any help or advice. -
Just got some black stock sportivo wheels 16s Looking for a 2005 toyota corolla sportivo side skirts rear spoiler/boot and front bumper. -
Driver's seat base leg support.
Just picked up a 2015 Ascent Sport and this is my first post. did a return trip Brisbane to Tweed heads and very pleased with it. I have one issue that I would like to correct if possible. I find that the front edge of the driver's seat is too low and provides no support at all under my legs just above the knees. I am looking at trying to elevate the front of the seat base if possible. Any suggestions welcome. -
Head light Relay Location corolla 2005 wagon Japan ver. 4AT
Hi guys, I was so many diagrams but my car is different. The head light Relay spot is empty in my car. Can anyone help me to find the relay actual location? When switch the head light on, I can hear click sound under the steering wheel but I can't see any relay there. -
Hi Tony, I don’t think so. When operating the hazard switch the dash lights are quite bright. When I turn either blinker on they are not as bright. I think it is an earth issue, maybe in the blinker switch. I’ll pull it out tomorrow and clean it with contact spray unless someone has a better idea 😁
