Hilux carby
Corey
Hey guys new here I need a carby for an 86-87 toyota hilux but I know nothing about these, I need the stock carby off of an 18R motor can anyone point me in the direction of what I should be looking at?
Thanks for your help.
G'day Corey and welcome to the forums,
The description you have stated above should be enough to get the right bits from your local wrecking yard, plenty of them in your phone book.
Thanks for the reply, I'll give em a go
Hi, below is a link of a site i found that the general public can use the wreckers hotline, all you do is list what you are after, where you are and it goes australia wide and if a wreckers has the parts you want then the email you with cost plus freigth to your door. i have a disability and cant get out much so this is great. hope this helps a few of you out there.
cheers
http://www.autoparts.com.au/viewparts.asp
Edited by 91ssr
      Drive shafts
    3. 10
      front brake calipers
      Drive shafts
    7. 315
    8. 10
      Dashlight dimmer
