knocking noise
jclark
I have a 93 Toyota Corolla. The noise is off and on. It happens on the straight and turns the same. It seems to get louder when I have the clutch in and Im coasting. I thought it was the axle so I changed it. But its still happening. It sounds like something is knocking against the axle as it spins. Can anyone tell me what this might be? Thanks
Josh
what do you mean you changed the axel? you mean cv's? which one did you change...
if noise is when you turn left its your right cv, if it happens when turning right your left is buggered...
also this knocking noise, is it a knock? or a ticking or a scrape ?
