pulling error codes off camry
tomee
hey guys,
i need to pull some fault codes for a 1996 V6 camry (3vz-fe)
my CEL is comming on and need to lknow what it is.
i remember doing it years ago but forgot what ports to short in the diagnosis port
thanks
ok i got the codes
and i get 5 blinks then 1 sec pause then another 5 blinks....
then it starts again
would that mean its pulling 2 x 5 codes? or a code of 55?
where can i check these codes to find out what it is?
Edited by tomee
i believe code 55 is to do with the knock sensors. otherwise, you could be misinterpreting the readings and its actually your oxygen sensor.
Edited by lateralus
looking at this chart, there is no 55
http://www.troublecodes.net/Toyota/
so im guessing both oxygen sensors? 5 + 5?
if it were code 55, wouldnt the first 5 be half second bliks, then the 2nd digit would be faster blinks?
if it is the knock sensor, where is that located?
Edited by tomee
      Wobble at the front
    2. 7
      Brake issues
    3. 10
      Best Oil for 2014 Lancruiser GXL 200 series TT V8 Diesel
    4. 25
      RADIO CODES "HELP"
    5. 17
      Wobble at the front
    6. 11
      rear wheel arch hole covers (3rd row seats removed)
      2013 Kluger grande Bluetooth music issues
      2010 MANUAL Prado with high speed acceleration hickup
    9. 10
    10. 1
