QLD:-AE112 bits zze/zzt231 jap spec
ZZE COROLLA ULTRA RACING ROOMBAR, goes in the back floorpan between your front seatbelts lowering anchor points. adjustable. $140
Ae82 factory two piece strut brace (bolt to firewall style one) $40
Ae112r levin mesh grill,genuine toyota used in very good condition $80
Ae112r prefacelift Levin foglights with plugs and short cut of loom $80
Ae112r indicator combo switch for foglight $80 or $140 for the switch and foggies together
2zzge rocker cover $80
2zzge air injected head stripped of valves cams etc $100
lots of standard s/h bits to clear out of my garage, if you need something just ask if its not listed
2zzge standard pistons and connecting rods out of very clean low km engine
2zzge standard valves, springs, retainers etc
2zzge standard cam shafts and vvti sprockets,oil pump housings...
Full 2.5 inch mandrel bent mild steel exhaust including high flow cat middle resonator and straight through rear muffler for a zze122 wagon, bolts up to 2zzge for 2zzge conversion or swap front flange and use on a 1zz. $400
Chrome exterior door handles for zze corolla(whole handles not just a cover) $50
facelift zze122 wagon tailgate garnish with the chrome stripe on it (off a white wagon)$50
post-14961-0-33067400-1340266040_thumb.j
zze122 late sedan grill for fitment to pre facelift cars, its the one that has the colour coded bars in the middle with the chrome outer, (light blue in colour)$50
post-14961-0-85548600-1340265946_thumb.j
zze123/zzt231 front rotors and calipers,with good cond pads in them still too! originally from the celica but i redrilled the rotors to suit the 4x100 also $200
standard zze122 front rotors and calipers with pads $100
prefacelift zze corolla aftermarket foglight kit, has wiring and a switch and a passengers side foglight, drivers side foglight is missing $50 new in the box still
JDM zzt231 ecu,no immobilizer lockout $100
Australian ZZt231 ecu ignition barrel and matching key $100
2004 zze123 sportivo electric window setup, includes:-
4x switches
4xlooms
4xmotors
4xsilver sportivo switch housings$150
2006 zze122 japanese facelift corolla elecs:-
rear setup including looms switches and motors(auto up n down)
drivers loom and switch(4 door auto up and down)
has the light up lil dots on the switches$150
1zz green injectorsset of 4 $40
2zz yellow injectors set of 4 $50
1zz power steering pump $20
1zz throttle body has small chip $20
2zz corolla intake manifold(no throttle body)$120
zze122 2002 wagon taillights left and right$50
zze122 2002 wagon rear bumper bar white $50
zze122 steering wheel and airbag $50
zze122 non abs rear wheel bearing bolt off hub units(new not long ago changed when i went 5 stud)
zzt231 celica passengers side airbag $30
zzt231 celica 2zz engine loom $100
zzt231 underdash and interior loom $50
zzt231 boot seal $10
zzt231 rear rotors $40 the pair
zzt231/zze123 rear calipers $50 the pair
manualised zze122/123/zzt231 steering rack, has been proffesionally stripped serviced and re-assembled as a manual rack. (yes the steering is heavy haha)$100
Jap spec ZZT231 180kph Speedo cluster $150
Jap spec ZZT231 climate control, includes radio surround facia with control panel ,wiring loom,blower box and heater box from under the dash $200
ZZT231 elec window switch unit $40
located in brisbane
post-14961-0-66507300-1317204909_thumb.j
post-14961-0-24590800-1340266433_thumb.j
Edited by daniboy
  • Replies 85
  • Created
  • Last Reply
Top Posters In This Topic
  • 4 weeks later...
Sorry if this seems like a stupid question..
Are the motorised motors, etc. for the windows all that is required to make the standard "manual" windows into power windows?
I am guessing, one would need new Door Cards so they don't have the holes where the handles used to be?
has the light up lil dots on the switches$300ono now $250
Do you have pictures of the whole setup?
ill take some pics tonight and post them up, they look just the same as any old motor,loom and switch, cant show the dots lighting up as they r not in a car anymore obviously
  • 4 weeks later...
bump just about to add new bits in the original post, 1zz and 2zz injectors, 1zz coilpacks,1zz throttle body(cable not wire )
  • 4 weeks later...
  • 4 weeks later...
bump
zze122 front rotors and calipers added $150 (recently machined rotors and installed the new series ct bendix brake pads)
Edited by daniboy
    6. 21
    7. 21
    8. 21
