FOUND: Auto Fold Mirrors
Brad!
I have pics and wiring instruction which I will upload soon, just on holidays forgot to load them before I left, they are wired back to front from their factory they folded with the ignition on and opened when it was off haha, they also have the function in the module to disable fold when you turn the ignition on and off three times in 5 seconds, and same to make them come on again, but,... for some reason they keep disableing by their lonesome and I have to keep activating them, and also the drivers one doesn't fold as far as I think it should. They r cool but I would only rate them 6/10 for function, they look 10/10 on the car thou.
i just installed my jdm toyota ones and the passenger side doesn't fold as far as the driver's. from my research that's normal for the passenger side (to compensate for the extra angle the passenger mirror is set). is yours RHD?
Edited by chicken
Mine turned up today - Should be installed on the weekend - They look the goods hope all goes well
nice, the front doors of the zze levins already has the wires for side indication and mirror folding in the looms so no need to feed extra wire through the door. just need to connect them in the dash
Edited by chicken
Installed them with a few hickups.
1. Wires wrong way around (Engine off = Open, Engine on = Closed)
2. The power mirror plug is not plug and play (At least not on Levin) so am yet to wire that up
3. Really bad vibrations even when the car is just at idle - The glass vibrates not the mirror
4. RH side does not fold flush like LH side
Apart from that they are pretty good bang for buck - Some pictures soon :)
    6. 21
    7. 21
    8. 21
    10. 3
