GROUP BUY
I have a 2017 and I warm it up, you will hear and feel the difference sound. -
I have three remotes for my car but only one works
Hey so to start with this video is useful I know you may have done all this etc but the key part is that he puts the remote fob near the right hand side of the wheel he is putting it close to the dash as that is where the programming signal comes from. with all the signal interference constantly around proximity can help a great deal. new battery or check battery in the fobs as well. I did see a way with other cars to use a working key fob to programme the others this may be a option but not sure. -
Dual Fuel (LPG Petrol) FZJ105 in Adelaide - What to do with?
Hi all, Per subject dont know what to do with my cruiser - LPG availability is getting quite low in Adelaide so I either need to remove the LPG or sell it to someone where LPG is stronger (Melbourne for example). Nothing wrong with it but I would be happy to part with it - unsure what to do Thoughts? -
329
Hi, I'm new here and wanted some advice on some exhaust mods... I have a 2005 Toyota corolla sportivo and was looking to get a new exhaust system. I was looking at cat back exhausts but don't know where to go from there. What else will I need for a nice sounding exhaust system and where should I look at getting the parts? Is eBay okay or no? I've seen a few post you've done on here and you seem like an expert! Thanks in advance -
Hi, I replaced the batteries with new ones, checked the contacts (they all looked good) and I still can't code them to the car. They were presumably working before (like years ago) but they don't now. I can get the car into programming mode, but then it's radio silence from there, no cycling the locks twice to indicate an unsuccessful pairing, absolutely nothing on both of them. I used the guide that's stickied in this forum (and cross referenced it with others online, the were all the same), tried it multiple times but no success. Any advice? -
Never before !!
I was driving my 2025 Camry hybrid along a flat section of the beach road when I noticed the “ total average” start dropping - I’d driven the car about 50 km on the day - but on this last 10 km section it just kept on dropping / not sure if it’s accurate !! I do know how to get the most out of the hybrid motor having driven 50 kin my 2022 model and 10 k in the 2025- it ended up dropping to 2.5 per 100km -
I’ve got 2025 and yes - still warm it up - especially in Melbourne/ it runs quite loud and rough at first - but then settles / I think it makes a difference -
6
Camry Hybrid. 4.2L/100km to 7.6L/100km
Can I ask what the SL Range indicator is showing when you fill the tank up / mine shows 730 km - -
6
Hi Tony - you’d need to drive it really hard to get 7.6 per 100km - that’s about what the ICE motor gets - 4.2-4.8 is about right - it takes time to learn how to drive a hybrid- but 7.6 is ridiculously high - and almost impossible -
Weird Range indication on 2025 sport model
Hi - This is my second Camry sport - My first was the 2022 model which I traded in February 2025 for a new model - my Range indicator is showing 735 km when full - is this what other drivers are seeing? My total average resets to 30 litres per 100 km - randomly my fuel gauge shows 8 full bars but the range indicator shows 578 km Half a fuel tank shows 278 km?? in my previous car - I would fill up - range indicator would read 1030 then just move down sequentially- not this model - is there any other owner of the same model who is experiencing this ?? Many thanks Paul
