Hay, i had an RA65 with a dud engine, so i got another one and swapped the engine over. i also grabbed a manual gearbox (as i didnt have one) out of an RA60 and put that in aswell. Most things from the working engine stayed with it, including starter motor and coil. tho now, it wont start. power is going to things like the lights, dash, even the sunroof, but it just wont turn over. nothing happens when i turn the key to 'start'. What am i missing???? where could the problem be?? im sure everyhting is plugged in the right spot. any ideas?? i have to have missed something... somewhere....
since your car was auto previously did you bridge the neutral start switch when you put the manual box in?
Not cranking? Try clutch-starting it. If that works, then it's the starter or associated wiring.
