flywheel/clutch issues
lylee
hi guys ive just had my clutch and flywheel changed
car has 75K on the clock. i have put a fidanza lightweight flywheel and exedy organic face hd cluch on.
it rattles at idle and when starting up, im just trying to figure out what the firetruck is wrong
provided it is an all-new kit, there should be no rattles, hot or cold. possible issues include, loose flywheel, loose pressure plate, loose springs in clutch plate, loose starter motor, all these things are quite rare, but possible. take it back to whomever did the job and seek their help.
cmon adam my life begins as i put the key in the ignition :D :D
my guess would be loose flywheel bolts, i even bought new flywheel bolts just to be safe. im seeing him tomorrow about it at indoor soccer. (yes i play indoor soccer with my mechanic/ and my turbo installer)
he has done many lotus 2zz's before so it should be quick to find the fault... touch wood
      help with clutch
    5. 3
      newbie from Queensland
      High mileage camry
      1981 Hiace ignition upgrade
    8. 2
    9. 1
