saging pedders springs
chef
Hi everyone please help.1 week ago i bought pedders lows for a corolla sportivo,the front drivers side sits 7mm lower than front passenger side and rear drivers side sits 5mm lower than rear passenger side.Is this normal after 1 week,the manager at pedders says its normal and they allow 10mm variance
Thanks in advance :)
Wow, I know not to buy Pedders now. A 10mm variance in height is huge if you do track work. On the street it would hardly be noticeable; handling wise, looks wise it may be possible but is pretty hard to tell when it's on different sides of the car.
Just make sure you are measuring it on level ground. Try it in a couple different places, or park the car in the opposite direction and measure again and see if it changes.
I have used pedders in my last 3 cars with no issues. I always bought the springs and fitted them myself. I have no experienced and sagging?
Thanks for advice everyone, probably worry for nothing.i was getting slight scrubbing so went down to 215/40/17 which is now all good.
I was also a bit shocked as well SuperDave about allowing a 10mm varience.
      Seat change
      1993 Corolla Seca CSI limited
      Corolla Seca For Sale
    6. 4
      2013 camry for sale
      Rav4 smart key keyless entry
