hey today i started hearing this weird noise from the sub it sounds like something is lose but i cant see anything it makes the noise even when its normal level and when i turn it up it gets worse. does this mean i have blown my sub?
sean
Gotta be specific with the noise. White noise? Buzzing?
Usually when speakers blow, they blow open circuit meaning that they won't produce a single sound anymore. Is it in an enclosure? Check to see that it is still solidly connected at it's terminal.
If you have another sub/speaker handy, try plugging this into your amp to make sure the amp is not the cause.
update was driven around today and the knocking has stopped but will be taking it out of its box and checking the coil and spiders and the amp
sean
    2. 0
      Remote start
    3. 1
    4. 0
    5. 9
      Android auto
    6. 9
      Android auto
    7. 1
      Turboed Corolla Overbuilt?
    8. 3
    9. 3
    10. 0
