Hi I have a 2011 landcruiser GXL I am experiencing this issue right now & stuck in Cocklebiddy. Can anyone assist please ?
Not ideal where you are but I would ry a couple of things:
Either disconnect the batteries (both) and leave for a good 10 mins - enough time for all
electrics to discharge.. Another one which worked for me was to disconnect the ECU - big
plug on the passenger side firewall. Same thing, allow for electrics/electronics to discharge.
Not practical for you at this stage but if you can get a Scangauge. This will allow you to clear the
codes.
Car has gone in limp mode. I had this problem several times whilst towing a caravan due to
a performance chip which would cause a limp mode. No more as I have had the ECU remapped.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
