Cleaning the Injen CAI
I just installed Injen CAI today
How do we clean it, i dun want to unscrew the bumper again..Any easy way to clean it?
How often should we clean it, given that I drive on normal road, not sandy and dusty roads? Thanks
Personally I did mine once every 6 months, using a K&N Recharger filter care kit, comes with instructions, you can find em at Supercheap etc. Did it more often if I thought it was necessary (dirt roads n stuff).
Yes, you will need to remove your bumper, yes its a pain in the ****.
i would do it every 5k, just do it when u change ur oil, keep a spare one just in case. whenever i do mine i just chuck the clean one on and leave the other one in solution and water for a night then dry + oil it and store it until the next 5k
mine's a K&N pod and i was told to just wash it with water about every 6 months or when needed
I believe if your skillful the bumper does not have to be removed just the rear mud guard however its easier if a little bit of the bumper is removed
doesn't really take long to remove :lol:
and it makes the world a WHOLE LOT easier for you :P
Any instructions to teach me how to remove bumber. Is it easier to remove the left bottom part (for installing foglight) rather than removing the bumper?
Mine is ZRE-154, but i guess should be very similar.
Have been searcing youtube for how to remove a corolla bumber, but the model was zre-122 sedan
      Corolla Seca For Sale
      Toyota Corolla Sportivo
    6. 2
      Toyota Landcruiser problems
    9. 7
      selling car
