Zre trunk release
Hey guys,
Does any body know if there is an aftermarket trunk release for the zre sedans?
Its kinda bugging me bcoz there is no handle on the trunk,so if its unlocked you still need to use the key or the lever inside next to the drivers seat to open the trunk.Im not sure about the hatchbacks though
Not that I am aware of.. I had the same problem with my mum's AE112, was pretty damn annoying!! <_<
The hatchbacks have a hydraulic (?) release, but I'm scared of the day that it doesn't open!! :blink:
powered by the battery too. so if you disconnect the battery.. or it dies, wont be able to open the boot.
      help with clutch
    2. 3
      newbie from Queensland
      High mileage camry
      1981 Hiace ignition upgrade
      Aftermarket Air Intake
      Heater problems
      Entertainment Unit Upgrade
