engine number location
can someone tell me where to find the engine number
for rego purposes
on a corolla AE82 sedan built 1988
its a 4cyl motor on the drivers side
a 5 speed manual box
4A M/T is on the rocker cover
and is there a downloadable pdf adobe type
repair manual for it
engine is covered in oil needs a good degrease
thanks
Edited by dirty hands
I do beleive I have a PDF manual to suit your beasty. Where in Brissy are you located or what area you work in?
Engine number is located on the engine block left drivers end. Towards the flywheel end I beleive.
Edited by SirNed
thats nice to know about the repair manual
probably just need torque specs if it needs motor work
I know I have to do a timing belt ?
Can that be done with the motor in ........
brissy inner northside is where I am
After I clean the motor I should be able to see that number
thanks for your reply
picture of the motor
found someone with a repair manual I can borrow
have to wait and see if it is helpfull eneough
what do the call this motor (for parts reason)
update
I cleaned of the area at the gearbox/flywheel end
and found 8 numbers stamped on what looks like the alloy
gearbox housing tight up against the block
is that the engine number or should it have letters and numbers
if this isnt the engine number where else would I look
thanks
That particular engine is a 4AC, if you have to be pedantic it is a 4ALC (the L in Toyota-speak means east-west/transverse mounting, so it won't get confused with north-south/longitudinal RWD applications like the AE71 and AE86)
The engine number should look something like this: 4Axxxxxxx, where the x's are numbers.
      New Member
    3. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    6. 199
      Advice Please
      A Greenskin
    9. 1
      Car Detailing Recommendations
