hey guys i have a st162 and it is overheating
i have checked
water pump looks fine spins well and all blades are still there
belt is fine
coolant flows from one side of motor the other same with radiator
i have replace
radiator cap
thromostat
the only think i can think of is the fans because they are on when you first start up (cold engine) but once warmed up they turn off done know what temputure but if anyone has more ideas would be a great help
and if some one has thremo fan wiring diagram would be great help
i have checked
belt is fine
i have replace
radiator cap
thromostat
how did you check the thermostat? also have you done a coolant system flush?
Is your head/gasket not cracked or blown?
Fans being on when cold and turning off when hot doesn't sound right at all, either the switch is wired in incorrectly or is busted itself.
Posted (edited)
yeah my thoughts excatly that is why i was wondering for a wiring diagram for fans
the relay switch works fine already checked it so all i can think is wiring
Edited by ba112y
Posted (edited)
i have checked
belt is fine
i have replace
radiator cap
thromostat
pulled thermostat out and it was cut so watter would flow freely past
havent presure flushes the system yet but found another discovery
the engine coolant drain plug was clogged up with what looks to be metal and dirt and no water came out so i believe they have used something like kemmy weld or something to stop a leak
and has clogged up some water gallerys
considering to pull of the head motor look like it may have been rebuilt already just going to flush it and see what comes out
still need wiring diagram for theormo fans
no smoke no milk shakes anywhere so i dont know if the head gasket is cracked or blown as of yet
thanks guys for your help and ideas
Edited by ba112y
removed or modified thermostats are usually a sign of some idiots attempt to solve a problem
removing the foot valve off the thermostat means about 20% of the water never goes thru the rad, but jsut goes round in circles in the engine
the fans only need to work when the gauge just over 'normal" . they are wired so they are "on" unless the sensor says its cold. that way they are fail-to-safe
overheating when idling/low revs is often a blockage
overheating only when driving is is often radiator based
overheating constantly is usually blown head gasket. other sign is moisture/milkiness under the oil filler cap. easy to test for this
  • 6 months later...
sounds like it was temp fixed blown head gasket now on its way out
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
