Which car should I buy
17 members have voted
Seca AE92R owner's manual
Hi, do a search "seca 1993 ae92r user manual", quite a few, for sale, pop up. Herb -
I recently purchased an unregistered Seca 1993 AE92R and it did not come with an owner's manual. Would someone be able to share their owner manual with me in an attached pdf please? -
7
Fuel usage
I bought recently a toyota rav4 2024 - XLE regular- and i get on long drives under 7 liters per 100 km, sometimes 6.5 liters per 100 km. But for the first half of the drive the gas mileage is around 8 liters per 100 km. Do you have similar gas mileage? -
Cruise Control Not Engaging
Got the same issue on my 2005. I am wondering if it's to do with the airbag recall replacement. Might have not been reconnected, or the clock spring doesn't support cruise control. I will have to make time to pull the airbag off and see whether it's visually obvious. -
Toyota Coaster 1992 BB21R Service Manual (need one)
Hi, I'm new here so not sure what help I can get... I need a new radiator for my Toyota Coaster BB21R but can't find one anywhere, any ideas? Also, I would like a service manual if there is one available (can't find that either). Thanks, John 0418 315 911 -
1993 Corolla Seca CSI limited
Could I please get a copy of the owner's manual that came with this car? I recently purchased the same car unregistered but it came with no owner's manual. Happy to pay for photocopying and postage. Or could you please tell me the part number that is inside the owners manual so I can try and find one on ebay. Many thanks -
15
Connecting spotlights to high beam on 2011 Hilux
Conrod. Thanks for this info. I spent about an hour trying to get my brain around this. Your solution worked perfectly.- 1
Navigation absent ? From apps 2016 atx model aurion
I've bought a 2017 Aurion. Can I connect the Toyota nav app to my settings? Can I get Google Maps to connect via Bluetooth? -
Landcruiser Prado (150 series) AVS suspension
Hi, I have a 2012 Prado (150 series) which is the LC5 (UK top end model) with AVS (suspension). My problem is that I find the AVS very brittle and a bit uncomfortable (on UK road tarmac) compared to my two previous LandCruisers - a 2001 Colorado and a 2006 Prado (120 series) with standard mechanical suspension. In the UK there are so few Prados sold with AVS that the dealers have no knowledge, and there is no Toyota UK technical support. Although I have no warning lights on the dash, there is no difference in the poor ride quality between Firm and Soft settings, thus I feel something must be broken between the dashboard switch and the dampers. Note that my dampers have been checked and two rears replaced, but with no improvement. Does anyone have experience or knowledge of this situation?
