Hi everyone,
I overfilled my 94 celica with engine oil and now have a problem.
Even though I drained the oil , put in a new oil filter and then filled the oil correctly I still have some oil leaking from somewhere behind the catalytic converter but can't see.
The car actually runs well apart from that.
Any ideas what I have done??
It has the 5S-FE right? So at the "rear" of the engine the leak could be cause by the 1. Sump 2. Valve Cover 3. Distributor(If the oil went high enough).
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
