Installing HKS Super Power Air Pod
Jaym
Hi Guys,
Is there any need for the Stock air filter to remain if i install a HKS Pod??
Can the stock filter just be taken out all together? or can the factory air box be eliminated.. They Just cause so much restriction to the potential amount of air intake!
Edited by Jaym
Hi Guys,
You will need to keep (or get a new) the stock MAF mount. however you can remove the stock airbox.
You can probaly find a premaid CAI on ebay, or get one made up for you.
Hi Guys,
Thanks man,
is there another sensor that goes into the air box??
Hi Guys,
On my 1NZ there is just the MAF sensor.
Thanks man,
Unifilter used to make a pod kit which allowed the maf to be relocated.
I rang unifilter.. bastards dont do them anymore.. MAF are ultra sensitive and unless positioned correctly according to volume of air passing through, car wont run
Yes, you need to keep the maf in the same diameter tube as it was from the factory otherwise the airflow calcs are out.
I was told as much as 1mm out of positioning can affect the function of the meter ?
As long as the diameter of the pipe is the same,and the penetration of the maf into the pipe is the same, and that the maf is no closer than about 100mm to the throttle body, it won't cause any problems.
      Aftermarket Air Intake
      Heater problems
      Entertainment Unit Upgrade
      Seat change
      1993 Corolla Seca CSI limited
      Corolla Seca For Sale
