On the Toyota audio systems... primarily those made by Fujitsu, which one is the power (12V and ACC) and ground pin?
is there a wiring diagram anywhere out there?
Reason I need to know this is that I have some Fujitsu Ten double din units that my friend handed in for testing to see if they work or not before he sends them off on an ebay sale. Most are from the zze corolla (2001-2007) and also from the camry of that time period as well.
thanks.
i found some wiring on ebay. if i'm correct, is it called a reverse harness? i presume the american toyota versions use the same connector yes?
Posted (edited)
Problem solved. Went to the wreckers and asked for the OEM harnesses and got them for free. :)
Edited by stevo1210
    2. 0
      Remote start
    3. 1
    4. 0
    5. 9
      Android auto
    6. 9
      Android auto
    7. 1
      Turboed Corolla Overbuilt?
    8. 3
    9. 3
    10. 0
