Hi evryone,
I have Aurion prodigy 2008 model, as I mention in the topic couple of days before when I adjusted the front passenger the airbag indicator light turned on, so I unpluged the connectors underneath the passenger and driver's seat and replugged it, and try the same topic forums no luck. Is there anyone could help me sort-out the problem. Most of the forums they talking about two different ports (DCL / OBD) but I found only obd port, anyone knows where is the other port?
You only have the ODBII port which is also referred to at times as the DCL port. In the Aurion, for sake of this discussion, they are the exact same thing.
Unless you have a specialist tool, there is a good chance that you are not going to be able to clear this code with any run of the mill OBDII diagnostic tool. The SRS warning light is a completely different code to clear compared to the Check Engine Light that these tools commonly clear. You should probably consider taking a trip to your dealer anyways to make sure that everything is in running order.
I took to toyota dealer, they did the test and they found that the code no:B1801 Drivers Squib( spiral cable), that sits under the driving wheel.
Cost me $440 + Lab-$110 dollars to replace and that was a good call, no more airbag message, they fixed the problem, Thnaks for advise Djokr.
I took to toyota dealer, they did the test and they found the error code no:B1801 Drivers Squib( spiral cable), that sits under the driving wheel.
    2. 0
      Remote start
    3. 1
    4. 0
    5. 9
      Android auto
    6. 9
      Android auto
    7. 1
      Turboed Corolla Overbuilt?
    8. 3
    9. 3
    10. 0
