Have very noisy drive belts on my 2001 Echo (2NZ-FE).
I have ID'd the Power Steering belt as '3PK850-R34-7J, however the Serpentine belt has no markings to identify it with.
Does anyone know what the correct belt type is (with Aircon) ????
Hey Mr Grumble
According to the Bosch Parts system there are possibly 2 belts
4PK1165 OR 4PK1180
Easiest way is to steal a relative's sewing tape measure, stick one end to the belt and measure around the whole belt(pulleys and all). This should get you close to what you need. Had the same with a Daihatsu Sirion with no markings on the belt
Just don't get caught with the tape measure. lol
P.S. The 3PK means 3 rib the 850 means 850mm total length
:o :o :o :o
My life's not worth that !!!
The last time I "borrowed" something of the missus, I came very near to wearing it.
Where is it written that Tupperware CAN'T be used to degrease in ????????
Anyway, I will see which one is nearest to the length required.
At a guess, I'd say one was with Aircon and the other without.
Cheers....
