Posted (edited)
Im fed up of the clutch in it at the moment, its a what 23 something, so ive downgraded to a 19 something off a corona that i was told is compatible however both bolt holes are on one side instead of one each side, is this do-able, will it be possible to make a bracket that could support this or does anyone have any tips with the stock one. it seems too long, riding out the gears a little and i get a bit of clutch slip in first, driving me bonkers. >:s
Edited by KIRIUS
Why not use an exedy HD clutch designed for a ST184... I happen to have one thats not had any use if you are interested.
Definately, what do you want for it? :rolleyes:
Well it cost me $350, but since i installed it already (the motor never ran though, so its never actually done anything) how does $250 sound for the clutch + throwout bearing.
Posted (edited)
:rolleyes: Edited by KIRIUS
Sounds good to me. :)
i'll have to get ahold of you when i get back to bris sometime in the next week to organise pick up.
Thanks heaps. ^_^
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
