Echo rear drum conversion to disc?
Lift yo'
I've done a Camry drum to disc. Toyota had a habit of using the same hubs if a model came with variatons of drum and disc, and disc all around. All you need is the parts from the all round disc version if there was one made and possibly the proportioning valve.
The Jap spec Yaris RS had rear disks.
Did a rear disk convo on my ae86 and used the drum proportioning valve, rear disks kept locking up even on light braking.. chucked in the disk prop valve and it fixed the rear locking first issue.
Hi
Has anyone ever performed a drum to disc conversion on an echo?
Been done plenty overseas. No one in Australia has done it though to my knowledge.
Why do you want rear discs? looks?
Hi
Got a link, i want to do this to the vitz.
and yes, only for looks.
Sorry for the tardy response, I don't always get email notifications from this board.
I haven't seen any tutorials on how to do it but I know Johnny has done it to his Echo.
http://yarisfans.com/forum/yaf_postst39_My-Echo---.aspx
      help with clutch
    5. 3
      newbie from Queensland
      High mileage camry
      1981 Hiace ignition upgrade
    8. 2
    9. 1
