A way to introduce more rolla's to the club
Head Unit with Apple CarPlay
8
- transmission stutter
(and 1 more)
Tagged with:
I immediately thought of sound deadener material which is available from JayCar as a potential solution. https://www.jaycar.com.au/combination-butyl-foam-super-sound-deadener/p/AX3689 -
Hi all, For some reason my 2012 Prado is having dramas starting first time every so often. Regularly serviced 192k KMs. Sounds really rough during initial failed attempt to start. Then on second attempt will start fine no drama's. Sometimes I can hear a little bit of that initial struggle during a cold start and will still start. Everything else seems to be running fine. Thinking it could be a fob or immobiliser issue? Have had the same result with both main and spare key fob. Booked mechanic in a couple of weeks for diagnosis but hoping to point him in the right direction. First video is the no start and the second is immediately after appearing fine. Cheers! cold start fail.mp4 success.mp4 -
1kzte throttle body
5
5
8
PZQ60-00525 Issue
I can confirm this worked for installing PZQ60-00345 from a 2020 70 series landcruiser into my 2000 100 series. It's an old thread but the only fix I could find - so bumping up.
