Hi im new here just wondering i want convert my 94 rwd hilux with a 253 any suggestion thanks
Davo
Unless you already have a 253 in your shed it would make more sense to me to use a 1UZ or 2UZ from a Lexus or Soarer
Or an injected 5L from a VS Commodore. I think there may be new rules where the conversion engine must comply with the emissions requirements that existed when the vehicle was made, basically meaning you want an engine that is newer than the car.
Even the V6 Ecotec motor would probably be better than a 253. They're cheap as chips too.
Marks 4WD adapters should have all the bits you need apart from the donor motor, or V6 conversions in Moree if you chose the Ecotec.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
