Hi Guys,
My Aurion has pop up with "Check VSC" message on the dash, and the OBD2 reports few faults with the O2 Sensor
Trouble Codes
DTC Description ECU
P2198 O2 Sensor Signal Biased/Stuck Rich Bank 2 Sensor 1 $7E8
Pending Codes
DTC Description ECU
P2241 O2 Sensor Positive Current Control Circuit Low Bank 2 Sensor 1 $7E8
Any ideas?
Cheers
As both banks have a pending code, it may be something they have in common. Quick and easy check is the A/F relay and fuse (there is only one relay and one fuse), per the below diagram:
At the moment, it's just detecting bank 2, sensor 1 as the one having issues. I worry that it might be the sensor that's dying, checked on ebay and they are expensiveto get.
The fuel usage on the highway is much higher now, up to 9L/100lm from mid 7Ls.
You're right, reading that while awake helps ...
~$289 on eBay ... time to speak with a wrecker?
    2. 0
      Remote start
    3. 1
    4. 0
    5. 9
      Android auto
    6. 9
      Android auto
    7. 1
      Turboed Corolla Overbuilt?
    8. 3
    9. 3
    10. 0
