Bulb replacement
juvenile
Got home from work tonight and as I walked behind the car I noticed a tail light out so decided to fix it the traditional way,yes by tapping it :D it worked but it's on its way out..
I've always replaced them with Narva bulbs over the years, seem OK but don't last as long as the originals.
Does anyone get them from Toyota or not worth it?
any recommendations or stick with Narva?
How many times have you replaced them?
Only one brake light has been replaced in the >100 000km of driving, in the rear right. (replaced @ 70000kms)
And only recently was the rear right parker replaced.
Both replaced with Toyota parts.
You may want to test the brightness of LEDs?
Haven't needed to replace any,yet.. It's the outside left one,parker...seems to be fine tonight,,
What do you mean by testing the LED brightness??
Replacing the halogen bulbs with LED bulbs. I have tested a T10 LED bulb in the parker, and they seem to be the same brightness as the halogens in Daylight.
Haven't tested the brake lights yet.
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    4. 199
      Advice Please
      A Greenskin
      Car Detailing Recommendations
      Landcruiser 200 GPS
    9. 11
      300 series turbo issues
