That's the parking/ side/ running light. Are you planning to go for the facelift headlights? The facelift model headlights have a separate high & low beam which will require some work on the wiring side.
Interesting.
If youve seen my members ride thread about my rav4.1 you would see that one of the things I have planned for the car was to buy an aftermarket front bar from xracing. The '97 lights fit the frontbar, so I guess Id need to swap the indicators since my year models wouldnt suit.
If its a simple swap (ie- the indicator lights are the same), I guess Id just use the indicator part and ignore the park light on it when the time comes.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
