Replacement Wheel Specification
Thanks jeffbro, thats the two bits I can't readily measure, got the calipers out to measure the centre hole and we are done. I am just holding off in hope of landing originals before I go down the aftermarket track but it seems that most the nice wheels are not available in 6.5 x 16 anyway.
there are 16x7's or 16x8's as well,
It's on a set of nearly new dunlop tires so I don't really go to a wider rim. No advantage in using fancier tyres out here on bush roads anyway, just adds to running cost when you put a rock through one.
      help with clutch
    5. 3
      newbie from Queensland
      High mileage camry
      1981 Hiace ignition upgrade
    8. 2
    9. 1
