What Engine???
AE92 Twincam Seca
4AGE is the powerful performance engine, and it has EFi. It revs to about 7600rpm and on the cam covers it says "Toyota Twin Cam 1600" or something
4A-C is the 1.6 Carby version, with the granny spec head and a fair bit of less power. << This is the one you have
Well then I better start saving my pennies for a 4AGE then..
Question though, if i do a conversion to i have to change the loom and back brakes cos they are drums
You will need the ECU and engine wiring etc from the 4AGE donor car, along with the fuel tank, pump and lines (as EFI tanks are different to carby ones). The rear brakes can stay as drums if you want, but obviously discs are better.
In saying all that, the cost of getting a whole 4AGE conversion + brakes + fuel stuff etc isn't that much less than just buying a whole AE92 SX (or buying a whole parts car and just swapping all the good bits over). Complete running registered SXs are only about 2-3 grand these days, and still fairly common.
      New Member
    3. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    6. 199
      Advice Please
      A Greenskin
    9. 1
      Car Detailing Recommendations
