Corolla 2008 brake fluid flush
Anubis
Hey guys,
I have a Toyota corolla ascent 2008. I need to flush the brake fluid. I bought genuine Toyota brake fluid and I'm thinking of doing it by myself or give to a mechanic to do it for me.
If I do it myself I need to know the best way to do it with tools and steps and whether there is a garage that I can hire for an hour or two to do it.
If I'm to give it to a mechanic I need to know how much it will cost given that I will provide the brake fluid. Also if you know a good mechanic around Sydney cbd or meadowbank
Cheers,
Ramses
if you really want a mechanic to do it.. i'll ask mine, he's worked on my corolla + I my skyline i had, so i trust him. He's a mobile mechanic so he'll come to you (meadowbank). I'll call him up tomorrow and get a quote for you
Thanks -prozak,
Can I have the name and contact for your dealership. Also if you know, which method is used to flush the brake fluid? 2-man-job, 1-man-job with a tool (pressure, vacuum or ??)
Thanks ohy34h,
Mobile mechanic is a great idea if he really knows what he is doing. One of my friends got one and it was not the best idea ever but if you know him that's fine. I just need a quote and details about the method he will use to flush the brake fluid.
Thanks -prozak,
U can go to pretty much any dealer and expect to pay around that, And as for which method depends on the tech working on the car. Some use gravity bleed, pressure by someone pumping the pedal, or vacuum and having a brake sucker on the nipple..
It's a Holden dealership..
Hey guys,
Cheers,
Ramses
i have done it twice, costs $80 each time.. but I think you might need to check your pad first.. check youtube for DIY, you need a bleeding kit.. ZRE needs 1 Litre of fluid
Edited by ben yip
Hey guys,
Cheers,
Ramses
Check the pads first? to see if they need replacement?
what about the sequence of doing it for Corolla 2008? is it
1. Rear Right
2. Front Left
3. Rear Left
4. Front Right
do you have a procedure handy?
which method did you use? Gravity or Pressure? can you give me more details.
Hey Guys,
Just replaced the front brake pads in my Toyota corolla but I didn't bleed brake system after that. Tested the car and I found that it brakes slowly.
Is that because I didn't bleed brake system? Or it could because the piston to stuck after I compressed it to accommodate the new pads.
Any ideas to diagnose will be appreciated.
Cheers,
Anubis
You need to bed em in, pedal will feel soft like its not stoppin just give it alittle time
U shouldn't have to bleed em after pushin the piston back
Chill.
Thanks, i have done the below and it works fine now: not sure if the below is what you mean by bed em in or not:. It could be also because I drove it then parked then drove again. Not sure
INSPECT BRAKE BOOSTER
(a) Check the air tightness.
(1) Start the engine and stop it after 1 or 2 minutes.
Depress the brake pedal several times slowly. HINT:
• If the pedal can be depressed to the floor on
the 1st time, but cannot be depressed as far on the 2nd or 3rd times, the booster is airtight. If not, inspect the vacuum check valve.
• If the vacuum check valve is normal, replace the brake booster assembly.
(2) Depress the brake pedal while the engine is running, and stop the engine with the pedal depressed.
HINT:
• If there is no change in the pedal reserve distance after holding the pedal for 30 seconds, the booster is airtight. If not, inspect the vacuum check valve.
I will continue testing fo a few days and if no issues, I will try to post a procedure to share.
Do you ZRE 2008 workshop manual? I' m currently using Yaris workshop manual (the American version). Not quite accurate but better than nothing
First of all .. Why would u have a brake booster issue when all you did was brakes?
With ur car off, after u did the pads u should of pressed the brake pedal ( it will go far ) so the piston can be pushed out and be up against the pads...
Also just clarify what issues u are having after doing pads -_-
I don't have any issues any more. I did the bed-in and all good now
I wanna work on the rear brake pads. The dealer will charge me $85 for them. Can I get it somewhere else cheaper than that.? But I need toyota genuine one.
Do you have ZRE workshop manual.?
Next I will replace rear brake pads and flush the brake fluid hopefully it goes okay :)
I'm working on replacing the rear brake pads. I did a check and it seems to be different the the front brake pads in-terms f assembly
I think I should be removing the 2bolts for the 2 slide pins, release hand brake then ??? Then remove the caliper
What else I need to remove to get the parking cable out of the way?
Any ideas?
Not seeing the rear pads setup, I'm going out on a limb seeing as I've done dozens of different cars, remove the lower bolt for the caliper, slide it up then back. So u leave one pin on. Push the piston back, new pads, reinstall.. As for handbrake cable suss it out eh
Just inspected the rear break pads and they don't need to be replaced, still about 6mm of it. Once it gets down to 2mm
, I will replace them.
I will be working on flushing brake fluid. I will be using two bottles of Toyota brake fluid 500ml each and one man job brake bleeder kit. Any tips for flushing brake fluid?
Haha :) I will try not to. I will let you know how it went.
Today, I tried to start the car but I couldn't. It was obvious it was the battery. Called NRMA and they guy came and jump start it but he told me the battery needs to be replaced and he confirmed that once I stop it, it won't start again. Also he added that they do battery replacement service at $134. Out of the discussion I felt he is trying to sell the battery rep service to me. I left home and tried to restart the car it was okay.
I wanna make sure that the battery doesn't need to replaced. What tester should I use and what is the procedure?
Hydrometer if it's a Maintenance battery
Load test with a multimeter. Start the car and measure the voltage, ideally u want it above 10 I reckon if its below that it's lazy...
Check charge rate aswell
Make sure it doesn't have a dead cell..
I ended up changing the battery with a free maintenance battery from NRMA 3 years warranty at $150. Not sure if this is a reasonable price or a rip-off given that he got the old battery.
I have done the flush of the brake fluid finally and braking seems to be fine :)
I have a question regarding the best place for the fire extinguisher. Under the driver seat, there is a plastic cover for the VIN of the car namely "Frame No.". If you remove this plastic cover you will see the VIN as well as two rectangle holes in the frame of the car. The distance between the 2 holes is 19cm and the hole width is 2cm by 8mm. Can I use these two holes to mount th fire extinguisher safely? If yes, is there any mounting kit where easily I can install and stick the extinguisher to?
What is your recommendation for the best place to install the fire extinguisher?
Here you go! Me and another ZRE owner made up this bracket and put it on the passenger side; Requires no drilling into the chassis whatsoever. :)
Thanks, I like it. Brilliant
Can you give me more details how can I make something similar?
That's what you need. You don't have to buy exactly the two black metal pieces, as long as something strong enough and lets you screw everything together.
You can unscrew the front screws (black) for the seat; they are 14mm. For ease, buy right angled brackets that have 14mm holes pre-drilled (one side for the chair and other for the metal bracket that will be attached to the F.E. bracket). Make sure you check whehter you can attach a 14mm to the F.E. bracket, otherwise you would have to do what we did (a bit more work); we bought right-angled brackets with 10mm pre-drilled holes and drilled 14mm holes on one side for the chair screws and used 10mm screws/bolts to attached the metal bracket and F.E. bracket to the other side.
Hope that helps! :lol:
