Hi all,
Well some A$$hole stole my LED light from my spoiler last night.
I called Toyota and got a quote of $250+ for a replacement!!!
So i have found this....
LED light
I measured the gap and it seems 274mm is the correct sizing....
but i just wonder as my old wiring just clipped in, will i have to cut the clip off to get this new one installed??
Contact the seller and ask if they supply plugs, if not do your research on what kind of plug it is and buy one off eBay,
If that yields no results then I would solder the end of the wires in the same shape as the male pins that would fit into the plug, then insert them into the female end, that way you aren't butchering your factory wiring whilst still maintaining a strong connection to the plug
    2. 0
      Remote start
    3. 1
    4. 0
    5. 9
      Android auto
    6. 9
      Android auto
    7. 1
      Turboed Corolla Overbuilt?
    8. 3
    9. 3
    10. 0
