wet aurions
zedder
whereabouts in the boot? i have a similar issue with the left side of the boot, wondering if it's a common issue or not. this occurs when there's rain and after i wash the car.
I'll just put my .02 in here...
Had the 1st service done on my sportivo less than 6 months ago, and apparently theres a recall on one of the tail light fittings, as it didn't create a good enough seal. Mine was replaced when they did the service. Perhaps if you call your local Toyota service centre and find out if this is a problem with your model?
It may be a problem with 09 onwards, post-facelift...
perhaps so. you may be right. i'm suspecting the water to be entering via either tail light, as i notice leakage through the left side to the spare wheel, which i question is the water coming in through the left taillight, but after many visits to the dealer, the problem is yet to be verified. However, the recall was amed for facelifted variants built before the start 2010, if my memory serves me correct, but mine was built in Feb of '10.
      ASV50 Camry Head Unit Options
    5. 14
      Hi from Wagga
    8. 2
    9. 2
    10. 2
