I am wondering if there is problem putting 235/40/R17 rims on a Corolla 2002. The standard rims are 195/60/r15. Eg. would they be illegal?
u can go 2 inches more than stock rims. so you're good :)
Thanks for the info.
Will they scrub?
Has anyone put these size wheels on corolla 2002?
  • 5 weeks later...
Will they scrub?
http://www.exploroz.com/vehicle/tyres/sizecalc.aspx
Results for your selected Wheel/Tyre 1 Rolling Radius 307.5mm Circumference 1932.08mm Diameter 615mm Wheel Cover Size Size 001 Results for your selected Wheel/Tyre 2 Rolling Radius 309.9mm Circumference 1947.16mm Diameter 619.8mm Wheel Cover Size Size 001 Differences between Wheel/Tyre 1 & 2 Rolling Radius 2.4mm Circumference 15.08mm Diameter 4.8mm When your speedo reads 100km/hr you're actually at 100.77 km/hr
near perfect fit, depending on the offset - you might just squeeze though with out having to roll your guards
depends on offset and ride height, maybe do a test fit?
235 is pretty wide
      Tyre Sale Specials
    4. 10
      Remote start
    9. 10
    10. 10
