2zz-ge data logging ?
hi guys who has a corolla or sportivo with a 2zz -ge engine that is using an after market ecu ?
can anyone answers i have ?
can you still data log engine temperature with the normal engine temperature sensor ? or do you need to have another sensor added into a coolante pipe to do this ?
also has anyone had problems with the speedometer ETC not working ?
thanks again scott
the majority of aftermarket ECU's will work fine with the stock ECT sensor, just set it up as a standard NTC sensor for calibration. The stock coolant guage wont work without piggybacking the stock ECU into the system to run it or making an aftermarket box of tricks to convert one of the ECU outputs to provide the signal required. Anthony from Kaizen Garage has made a converter that can do this for adaptronic ECU's.
awsome thanks for the info :D ... do you have an e-mail or does he have a web site? as i may need to get in contact with him :) sorry am from scotland and havnt heard of the garage before :)
Edited by scott5
      Toyota Corolla Sportivo
      Toyota Landcruiser problems
    5. 7
      selling car
      Fuel Filter - Change or not
      2013 cruiser gxl ute
    8. 2
    9. 2
